[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Markus Metz
markus.metz.giswork at gmail.com
Sat Jan 17 11:40:22 PST 2015
On Fri, Jan 16, 2015 at 11:25 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Jan 16, 2015 at 10:01 AM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> The fixes are all thoroughly tested (I guess I have never
>> before tested vector topology so thoroughly...).
> Hi Markus,
> will you be able to turn your tests into testsuite scripts? It is additional
> work but it gives us possibility to ensure that nobody will break what you
> did and it should save it your time in the long run.
I modified v.generalize in my local copy to become a topology
debugging tool. The debugging tools could be activated with an
environment variable which would need to be set by the test suite.
If I turn the tests into a test suite script, I will use a vector from
the the full version of the North Carolina sample dataset. Is this ok?
> Let me know if you miss something in testing framework which would help you
> to write the tests.
I would like to provide a command and the test suite must check the
return status. If someone else could then turn this into a testsuite
script, that would be great!
Markus M
