[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 16 14:25:33 PST 2015
On Fri, Jan 16, 2015 at 10:01 AM, Markus Metz <markus.metz.giswork at gmail.com
> wrote:
> The fixes are all thoroughly tested (I guess I have never
> before tested vector topology so thoroughly...).
Hi Markus,
will you be able to turn your tests into testsuite scripts? It is
additional work but it gives us possibility to ensure that nobody will
break what you did and it should save it your time in the long run.
Let me know if you miss something in testing framework which would help you
to write the tests.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150116/a2d423a8/attachment.html>
