[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Vincent Bain bain at toraval.fr
Tue Jan 27 12:35:54 PST 2015
As far as I can help the startup screen issue, I'll try to make a point
tomorrow on the wiki. There is no doubt a solution can be found in a
couple of days, is there ?
V.
 Le mardi 27 janvier 2015 à 10:31 +0100, Markus Neteler a écrit :
> On Tue, Jan 27, 2015 at 9:46 AM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
> > On 21/01/15 10:56, Markus Neteler wrote:
> > Coming back to this after a while. I think this is exactly the question:
> > should we wait until everything is backported, or should we fix a date and
> > if some things are not backported, they will have to be in the next point
> > release ?
> The important blocker is now the welcome screen issue.
> > In the proposed release procedure backports should be done before the hard
> > freeze and the first RC...
> Sure. But we can definitely not release G7 with a startup identical to G6.
> Too bad that nobody cared in the past 2 years but only now.
> > Just to be sure: I'm not criticizing the way the release is handled, just
> > using this current release to illustrate the ideas of the proposed release
> > procedure. And some of the experiences of the current release could maybe
> > feed back into amendments of that proposal.
> Yes, agreed.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
