[GRASS-dev] porting i.spec.sam to grass7
Markus Neteler neteler at osgeo.org
Mon Jan 19 22:58:46 PST 2015
On Jan 19, 2015 7:13 PM, "Yann Chemin" <ychemin at gmail.com> wrote:
> Seems to be the last hurdle..
> ogr_api.h
> In file included from
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/digit.h:3:0,
>                  from
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vector.h:4,
>                  from main.c:27:
/home/yann/dev/grass_yann/dist.x86_64-unknown-linux-gnu/include/grass/vect/dig_structs.h:27:21:
fatal error: ogr_api.h: No such file or directory
>  #include <ogr_api.h>
> compilation terminated.
See the last line in this fix
https://trac.osgeo.org/grass/changeset/64242
... one more include you need.
Markus
> On 19 January 2015 at 22:31, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Jan 19, 2015 at 5:31 PM, Yann Chemin <ychemin at gmail.com> wrote:
>> > Hi,
>> > porting to grass7 i.spec.sam (grass-addons/grass7/imagery/)
>> > I am getting a set of complaints like this:
>> > OBJ.x86_64-unknown-linux-gnu/spec_angle.o:(.bss+0x158): multiple
definition
>> > of `Avector'
OBJ.x86_64-unknown-linux-gnu/main.o:/home/yann/dev/grass-addons/grass7/imagery/i.spec.sam/main.c:92:
>> > first defined here
>> > while it is actually defined in global.h, and global.h is read in
main.c as
>> > well as in spectral_angle.c . The line 92 in main.c is the first
appearance,
>> > without declaring Avector (just using it).
>> [neteler at pgis_north i.spec.sam]$ grep Avector *.h
>> global.h:GLOBAL VEC *b, *Avector;
>> I guess the GLOBAL declarations need to be fixed as time ago in other
>> GRASS modules using "extern". See for example:
>> http://trac.osgeo.org/grass/changeset/32675/grass/trunk/raster/r.to.vect
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150120/4a539e37/attachment-0001.html>
