[GRASS-dev] [GRASS GIS] #2490: EPSG code not saved in PROJ_EPSG
trac at osgeo.org
Tue Jan 20 03:18:01 PST 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Projections/Datums | Version: svn-releasebranch70
Keywords: g.proj | Platform: MSWindows 7
Cpu: x86-64 |
Changes (by neteler):
* keywords: => g.proj
Comment:
Replying to [comment:1 hellik]:
> r49298: Retain EPSG code, if available, into a metadata file.
This doesn't seem to work yet or the if() conditions are not fulfilled.
It would also cover the case of creating the Location from the startup
script as well as the location wizard since in Python g.proj is called
from there:
http://grass.osgeo.org/grass71/manuals/libpython/_modules/script/core.html#create_location
Yet the bug in g.proj is to be understood:
g.proj epsg=4326 location=mylatlong
--> no PROJ_EPSG generated as expected
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:3>
