[GRASS-dev] Making start of GRASS GIS easier for newcomers
Anna Petrášová kratochanna at gmail.com
Fri Jan 23 08:48:33 PST 2015
On Fri, Jan 23, 2015 at 10:34 AM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi,
> On Fri, Jan 23, 2015 at 2:10 PM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> That is why I suggested a minimal (minimal information content)
>> welcome screen with one OK button and one change button. The OK button
>> should be prominently placed, the user must immediately see that all
>> is needed to get started is to press OK. This welcome screen could be
>> written such that practically nothing but wx needs to be imported,
>> which means that the splash screen can go away. Because of the little
>> amount of content (text + buttons), there would be enough space for
>> graphics even on small screens.
>> You could have drop-down boxes for location and mapset to offer a
>> choice instead of fixed text.
> Do I understand correctly that such drop-down boxes to change current
> location and mapset are to be found at the stage when GRASS is already
> started? Meaning that you are in a XY empty location and you can choose to
> go directly to a different one without restarting GRASS? If this is your
> proposal, I  think that this would indeed do a huge difference to anyone
> working in grass, not only newcomers, in terms of practicality
> That's already there. I am not sure if it makes such a huge difference.
Anna
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150123/8bd1aca0/attachment-0001.html>
