[GRASS-dev] i.spectral error in trunk
Yann Chemin ychemin at gmail.com
Fri Jan 23 10:16:14 PST 2015
got this error message when running i.spectral.
btw, is there a plan to have i.spectral running in the GUI with the other
tools?
i.spectral group=m3 at yann
coordinates=-23.4344978039,-3.00860909257
ERROR: Neither MONITOR (managed by d.mon command) nor
GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
  File "/usr/local/grass-7.1.svn/scripts/i.spectral", line
241, in <module>
    main()
236, in main
    draw_linegraph(what)
179, in draw_linegraph
    x_title='Bands', y_title='DN Value')
  File
"/usr/local/grass-7.1.svn/etc/python/grass/script/core.py",
line 375, in run_command
    return handle_errors(returncode, returncode, args,
kwargs)
  File
line 310, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['d.linegraph', 'x_title=Bands',
'x_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
OK/15217.0/data_x',
'y_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
OK/15217.0/data_y_0', 'y_title=DN Value', 'title=Spectral
signatures', 'y_color=red'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150123/32cec265/attachment.html>
