[GRASS-dev] i.spectral error in trunk
Yann Chemin ychemin at gmail.com
Fri Jan 23 10:19:40 PST 2015
Following the error, launched manually d.mon wx0
ISIS-GRASS 7.1.svn (M3):~/M3 > d.mon wx0
ISIS-GRASS 7.1.svn (M3):~/M3 > i.spectral group=m3 at yann
coordinates=-23.4344978039,-3.00860909257
GRASS_INFO_WARNING(15380,1): Unsupported command d.linegraph.
On 23 January 2015 at 23:46, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> got this error message when running i.spectral.
> btw, is there a plan to have i.spectral running in the GUI with the other
> tools?
> i.spectral group=m3 at yann coordinates=-23.4344978039,-3.00860909257
> ERROR: Neither MONITOR (managed by d.mon command) nor
> GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
> Traceback (most recent call last):
>   File "/usr/local/grass-7.1.svn/scripts/i.spectral", line
> 241, in <module>
>     main()
> 236, in main
>     draw_linegraph(what)
> 179, in draw_linegraph
>     x_title='Bands', y_title='DN Value')
>   File
> "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py",
> line 375, in run_command
>     return handle_errors(returncode, returncode, args,
> kwargs)
>   File
> line 310, in handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None
> ['d.linegraph', 'x_title=Bands',
> 'x_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
> OK/15217.0/data_x',
> 'y_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
> OK/15217.0/data_y_0', 'y_title=DN Value', 'title=Spectral
> signatures', 'y_color=red'] ended with error
> Process ended with non-zero return code 1. See errors in the
> (error) output.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150123/b264f458/attachment.html>
