[GRASS-dev] i.spectral error in trunk
Yann Chemin
ychemin at gmail.com
Fri Jan 23 10:24:45 PST 2015
it does display something with -g flag
On 23 January 2015 at 23:49, Yann Chemin <ychemin at gmail.com> wrote:
> Following the error, launched manually d.mon wx0
> ISIS-GRASS 7.1.svn (M3):~/M3 > d.mon wx0
> ISIS-GRASS 7.1.svn (M3):~/M3 > i.spectral group=m3 at yann coordinates=-23.
> 4344978039,-3.00860909257
> GRASS_INFO_WARNING(15380,1): Unsupported command d.linegraph.
> On 23 January 2015 at 23:46, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi,
>> got this error message when running i.spectral.
>> btw, is there a plan to have i.spectral running in the GUI with the other
>> tools?
>> i.spectral group=m3 at yann coordinates=-23.4344978039,-3.00860909257
>> ERROR: Neither MONITOR (managed by d.mon command) nor
>> GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
>> Traceback (most recent call last):
>> File "/usr/local/grass-7.1.svn/scripts/i.spectral", line
>> 241, in <module>
>> main()
>> 236, in main
>> draw_linegraph(what)
>> 179, in draw_linegraph
>> x_title='Bands', y_title='DN Value')
>> File
>> "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py",
>> line 375, in run_command
>> return handle_errors(returncode, returncode, args,
>> kwargs)
>> File
>> line 310, in handle_errors
>> returncode=returncode)
>> grass.exceptions.CalledModuleError: Module run None
>> ['d.linegraph', 'x_title=Bands',
>> 'x_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
>> OK/15217.0/data_x',
>> 'y_file=/home/yann/GRASSDATA/M3/yann/.tmp/Yann-
>> OK/15217.0/data_y_0', 'y_title=DN Value', 'title=Spectral
>> signatures', 'y_color=red'] ended with error
>> Process ended with non-zero return code 1. See errors in the
>> (error) output.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150123/66747a03/attachment.html>
