[GRASS-dev] PDF links in modules manuals should be opened externally (OS Web browser)
Vaclav Petras
wenzeslaus at gmail.com
Sat Jan 24 21:10:41 PST 2015
On Sun, Jan 25, 2015 at 12:00 AM, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> Clicking on the i.spec.unmix PDF link in the module manual tab returns the
> PDF in raw text format (not-human readable) in the same integrated viewer.
> Maybe opening it in the OS Web Browser would be an option, or?
> Can you take some screenshots or explain more? I just tried the HTML file
in source code and it is fine. The link to PDF opens the PDF file in
browser. I'm using Firefox which uses PDF.js for PDFs.
If the separate tab should be opened that's different think. People seems
not to agree what's right. Some say you can use target="_blank" some other
that it is a bad practice almost always and you should leave it completely
on the user (even non-advanced user can usually go back).
Vaclav
PS: The i.spec.unmix manual is not online (generated)?
http://www.grassbook.org/neteler/papers/neteler2005_IJG_051-061_draft.pdf
> Yann
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150125/5d24c4c0/attachment-0001.html>
