[GRASS-dev] PDF links in modules manuals should be opened externally (OS Web browser)
Yann Chemin ychemin at gmail.com
Sat Jan 24 22:40:57 PST 2015
Yes Vaclav,
Run I.spec.unmix from grass, then go to the manual tab, the click on PDF,
the link in the reference section, within the gui of the module I find that
problem.
Thanks
Yann
On Jan 25, 2015 10:41 AM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Sun, Jan 25, 2015 at 12:00 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi,
>> Clicking on the i.spec.unmix PDF link in the module manual tab returns
>> the PDF in raw text format (not-human readable) in the same integrated
>> viewer.
>> Maybe opening it in the OS Web Browser would be an option, or?
>> Can you take some screenshots or explain more? I just tried the HTML file
> in source code and it is fine. The link to PDF opens the PDF file in
> browser. I'm using Firefox which uses PDF.js for PDFs.
> If the separate tab should be opened that's different think. People seems
> not to agree what's right. Some say you can use target="_blank" some other
> that it is a bad practice almost always and you should leave it completely
> on the user (even non-advanced user can usually go back).
> Vaclav
> PS: The i.spec.unmix manual is not online (generated)?
> http://www.grassbook.org/neteler/papers/neteler2005_IJG_051-061_draft.pdf
>> Yann
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150125/b03abf34/attachment.html>
