[GRASS-dev] Sampling STRDS at point location(s)
Markus Neteler neteler at osgeo.org
Mon Jan 26 11:06:25 PST 2015
On Fri, Jan 16, 2015 at 4:05 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Sören,
> Your idea to include this functionality into t.vect.observe.strds is probably the most elegant solution, as long as no C-developer prefers to remove the 400 maps limit in r.what...
In r.patch a similar limitation problem was solved in
http://trac.osgeo.org/grass/changeset/23499
Would be great to get rid of that also in r.what.
Markus
