[GRASS-dev] Sampling STRDS at point location(s)
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Jan 28 07:10:04 PST 2015
BTW: is not this ticket for r.what outdated and can be closed?
https://trac.osgeo.org/grass/ticket/32
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: 26. januar 2015 20:06
To: Blumentrath, Stefan
Cc: Sören Gebbert; GRASS developers list (grass-dev at lists.osgeo.org)
Subject: Re: [GRASS-dev] Sampling STRDS at point location(s)
On Fri, Jan 16, 2015 at 4:05 PM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Hi Sören,
> Your idea to include this functionality into t.vect.observe.strds is probably the most elegant solution, as long as no C-developer prefers to remove the 400 maps limit in r.what...
In r.patch a similar limitation problem was solved in
http://trac.osgeo.org/grass/changeset/23499
Would be great to get rid of that also in r.what.
Markus
