[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
trac at osgeo.org
Tue Jan 27 12:16:15 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: projection import gdal ogr | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:5 mmetz]:
> Replying to [comment:3 mlennert]:
> > Replying to [comment:2 mmetz]:
> > > Replying to [comment:1 martinl]:
> > > > reprojection option available for r.in.gdal/v.in.ogr would a step
forward from user perspective.
> > > You would need to supply all options of [r|v].proj. Moreover, vector
data might need preprocessing (adding vertices to lines/boundaries) in
order to provide realistic and topologically correct results. The
reprojection option could IMHO be best implemented in a script which calls
r.in.gdal/v.in.ogr and then r.proj/(v.split + v.proj).
> > I had actually thought that it might be possible to integrate GDAL/OGR
library tools such as GDALWarpOperation and OGRCoordinateTransformation
directly into r.in.gdal/v.in.ogr.
> > But maybe you're right and we should not touch the general GRASS
structure of import into one location + reproject into another, and rather
use a wrapper.
> (Ongoing discussion on the dev-ml)
> My point for a wrapper script which calls r.in.gdal/v.in.ogr and then
r.proj/v.proj is about reprojection pitfalls.
I have created the addon script r.in.proj which imports and reprojects (if
necessary) a GDAL datasource. It is by purpose educational, i.e. the user
needs to specify the resampling method and by default the average target
resolution is estimated, but the input is not reprojected. This forces the
user to think about both the resampling method and a reasonable output
resolution. If in doubt, read the manual...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208#comment:6>
