[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
GRASS GIS trac at osgeo.org
Tue Jan 27 12:54:55 PST 2015
 Reporter:  mlennert                    |       Owner:  grass-dev@…
     Type:  enhancement                 |      Status:  new
 Priority:  normal                      |   Milestone:  7.0.0
Component:  Default                     |     Version:  unspecified
 Keywords:  projection import gdal ogr  |    Platform:  Unspecified
      Cpu:  Unspecified                 |
Comment(by annakrat):
 Replying to [comment:6 mmetz]:
 > Replying to [comment:5 mmetz]:
 > > Replying to [comment:3 mlennert]:
 > > > Replying to [comment:2 mmetz]:
 > > > > Replying to [comment:1 martinl]:
 > > > > > reprojection option available for r.in.gdal/v.in.ogr would a
 step forward from user perspective.
 > > > > You would need to supply all options of [r|v].proj. Moreover,
 vector data might need preprocessing (adding vertices to lines/boundaries)
 in order to provide realistic and topologically correct results. The
 reprojection option could IMHO be best implemented in a script which calls
 r.in.gdal/v.in.ogr and then r.proj/(v.split + v.proj).
 > > > I had actually thought that it might be possible to integrate
 GDAL/OGR library tools such as GDALWarpOperation and
 OGRCoordinateTransformation directly into r.in.gdal/v.in.ogr.
 > > > But maybe you're right and we should not touch the general GRASS
 structure of import into one location + reproject into another, and rather
 use a wrapper.
 > > (Ongoing discussion on the dev-ml)
 > > My point for a wrapper script which calls r.in.gdal/v.in.ogr and then
 r.proj/v.proj is about reprojection pitfalls.
 > I have created the addon script r.in.proj which imports and reprojects
 (if necessary) a GDAL datasource. It is by purpose educational, i.e. the
 user needs to specify the resampling method and by default the average
 target resolution is estimated, but the input is not reprojected. This
 forces the user to think about both the resampling method and a reasonable
 output resolution. If in doubt, read the manual...
 Thanks, that's great! Eventually, this should be a core module and should
 be incorporated in the import dialog. Although the gui should be simple,
 we can still force users to actively decide the method and resolution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208#comment:7>
