[GRASS-dev] [GRASS GIS] #2564: r.what: remove 400 maps limit and add some new output options
trac at osgeo.org
Wed Jan 28 15:16:02 PST 2015
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.what | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
I have just committed a new temporal module called t.rast.what in trunk
(r64349 - r64351) that utilized r.what to sample space time raster
datasets using vector points. It provides three output layouts that
transforms the r.what output into row or column layouts. It can run
several r.what processes in parallel using a maximum of 400 raster map
layer in a single r.what process.
Please have a look at it.
Any feedback about its performance, usefulness and handling is highly
welcome.
Improving r.what to allow more than 400 maps is simple, just edit the
fixed value in the source. But, editing this value may cause open file
handler limit problems with your OS. However, these limits can be adjusted
at kernel level configuration for Linux.
Implementing a more intelligent file handling solution requires more
effort.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2564#comment:1>
