[GRASS-dev] [GRASS GIS] #2564: r.what: remove 400 maps limit and add some new output options
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Jan 28 22:29:57 PST 2015
Great news! Thanks.
I shall test immediately.
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of GRASS GIS
Sent: 29. januar 2015 00:16
Subject: Re: [GRASS-dev] [GRASS GIS] #2564: r.what: remove 400 maps limit and add some new output options
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.what | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
I have just committed a new temporal module called t.rast.what in trunk
(r64349 - r64351) that utilized r.what to sample space time raster datasets using vector points. It provides three output layouts that transforms the r.what output into row or column layouts. It can run several r.what processes in parallel using a maximum of 400 raster map layer in a single r.what process.
Please have a look at it.
Any feedback about its performance, usefulness and handling is highly welcome.
Improving r.what to allow more than 400 maps is simple, just edit the fixed value in the source. But, editing this value may cause open file handler limit problems with your OS. However, these limits can be adjusted at kernel level configuration for Linux.
Implementing a more intelligent file handling solution requires more effort.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2564#comment:1>
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
