[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
trac at osgeo.org
Thu Jan 29 02:11:42 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: projection import gdal ogr | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:13 mlennert]:
> Replying to [comment:10 mmetz]:
> > Replying to [comment:6 mmetz]:
> > > Replying to [comment:5 mmetz]:
> > > > Replying to [comment:3 mlennert]:
> > > > > Replying to [comment:2 mmetz]:
> > > > > > Replying to [comment:1 martinl]:
> > > > > > > reprojection option available for r.in.gdal/v.in.ogr would a
step forward from user perspective.
> > > > > > You would need to supply all options of [r|v].proj. Moreover,
vector data might need preprocessing (adding vertices to lines/boundaries)
in order to provide realistic and topologically correct results. The
reprojection option could IMHO be best implemented in a script which calls
r.in.gdal/v.in.ogr and then r.proj/(v.split + v.proj).
> > > > > I had actually thought that it might be possible to integrate
GDAL/OGR library tools such as GDALWarpOperation and
OGRCoordinateTransformation directly into r.in.gdal/v.in.ogr.
> > > > > But maybe you're right and we should not touch the general GRASS
structure of import into one location + reproject into another, and rather
use a wrapper.
> > > > (Ongoing discussion on the dev-ml)
> > > > My point for a wrapper script which calls r.in.gdal/v.in.ogr and
then r.proj/v.proj is about reprojection pitfalls.
> > > I have created the addon script r.in.proj which imports and
reprojects (if necessary) a GDAL datasource.
> > Now there is also v.in.proj which imports and reprojects (if
necessary) a OGR datasource. It is still a bit noisy (lots of messages if
direct import fails).
> Great. Seems to work without problems in simple test.
> One question: why did you decide to not use the g.proj -j comparison
test before direct import here ? The current error message from the failed
direct import is a bit disconcerting.
I have changed this and synced r.in.proj with v.in.proj in r64359. First,
a temporary location is created from the input, this is fast. Then the
projections are compared (g.proj -j output) and, if equal, the input is
directly imported without reprojection. Otherwise, the input is imported
in the just created temporary location and from there reprojected to the
current location.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208#comment:15>
