[GRASS-dev] [GRASS GIS] #2566: v.net.*: allow separate output for each starting point
trac at osgeo.org
Thu Jan 29 03:34:10 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: v.net.iso v.net.alloc network graph | Platform: Unspecified
Cpu: Unspecified |
When using v.net.iso (also v.net.alloc and maybe others) with several
different starting points, I have to relaunch the module on each point if
I want separate output for each point and not an isochrone or allocation
only for the closest point. So I loop over the different starting points.
However, at each run, v.net.iso has to reconstruct the graph which takes
time making the loop quite slow.
Two ideas come to mind that might accelerate this:
1. Integrate the loop into the modules, e.g. with a flag indicating that
you want separate output per starting node. In this situation, the content
of output option would become a basename for all output maps.
2. Create a system which keeps the contructed graph in memory or in a
file allowing to use it over different runs.
Any of this sound feasible ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2566>
