[GRASS-dev] [GRASS GIS] #2569: Allow v.db.reconnect.all to handle database errors more graciously
trac at osgeo.org
Fri Jan 30 13:02:57 PST 2015
Reporter: ewcgrass | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Database | Version: unspecified
Keywords: | Platform: Linux
Cpu: x86-64 |
v.db.reconnect.all appears to stop at every database error it encounters
during migration of database tables from .dbf to sqlite (and likely others
too). While this provides a great opportunity to clean up incorrect
database tables, it destroys work flow.
It would be nice if flags could be added to allow v.db.reconnect.all to
skip errors and list them, while continuing to process the rest of the
database tables in the mapset. Then those tables which caused the errors
could be more easily audited and repaired.
This would be extremely useful for the numerous vector file migrations
that are necessary from GRASS 6.x to 7.0, but it may be too late to
incorporate it into version 7.0 at this time, which is why I suggest it as
something for version 7.1 or later.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2569>
