[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
trac at osgeo.org
Wed Jul 1 14:09:48 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.1
Component: Default | Version: svn-trunk
Resolution: | Keywords: utf, wxgui
CPU: x86-32 | Platform: MSWindows 7
Comment (by annakrat):
Please try this (with r64834 in place):
#!diff
Index: task.py
--- task.py (revision 65450)
+++ task.py (working copy)
@@ -232,7 +232,7 @@
if p.get('default', '') != '':
cmd += ['%s=%s' % (p['name'], p['default'])]
elif ignoreErrors and not suppress_required and not
ignoreRequired:
- cmd += [('%s=%s' % (p['name'],
_('<required>'))).decode('utf-8')]
+ cmd += ['%s=%s' % (p['name'], _('<required>'))]
elif p.get('value', '') == '' and p.get('default', '') != ''
and not ignoreDefault:
elif p.get('value', '') != '' and \
This was introduced in r61704 and seems to be not needed with r64834.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:19>
