[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
trac at osgeo.org
Wed Jul 1 14:52:24 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.1
Component: Default | Version: svn-trunk
Resolution: | Keywords: utf, wxgui
CPU: x86-32 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:19 annakrat]:
> Please try this (with r64834 in place):
> #!diff
> Index: task.py
> --- task.py (revision 65450)
> +++ task.py (working copy)
> @@ -232,7 +232,7 @@
> if p.get('default', '') != '':
> cmd += ['%s=%s' % (p['name'], p['default'])]
> elif ignoreErrors and not suppress_required and not
ignoreRequired:
> - cmd += [('%s=%s' % (p['name'],
_('<required>'))).decode('utf-8')]
> + cmd += ['%s=%s' % (p['name'], _('<required>'))]
> elif p.get('value', '') == '' and p.get('default', '') !=
'' and not ignoreDefault:
> elif p.get('value', '') != '' and \
> This was introduced in r61704 and seems to be not needed with r64834.
tested locally with with r64834 in place: no error anymore.
so let's test with the next nightly build and go on to the next RC!
thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:20>
