[GRASS-dev] GRASS 7.0.1
Helmut Kudrnovsky hellik at web.de
Fri Jul 3 06:09:13 PDT 2015
Helmut Kudrnovsky wrote
> just tested in trunk and nc data set, I get this error:
> g.copy vector=firestations at PERMANENT,myfire
> xcoor and ycoor columns added
> opened v.to.db, choosing myfire in the drop down menue:
> Traceback (most recent call last):
>   File "C:\OSGEO4~2\apps\grass\grass-7.1.svn\gui\wxpython\gu
> i_core\forms.py", line 2221, in OnSetValue
> self.OnUpdateValues(event)
> i_core\forms.py", line 628, in updateValuesHook
> self.SetStatusText('
> '.join(self.notebookpanel.createCmd(ignoreErrors = True)))
> UnicodeDecodeError
> 'ascii' codec can't decode byte 0xf6 in position 11: ordinal
> not in range(128)
> choosing option what to upload to attribute table:
> UnicodeDecodeError
> 'ascii' codec can't decode byte 0xf6 in position 12: ordinal
> not in range(128)
> UnicodeDecodeError
> not in range(128)
> mmmhhh if I remember, we have had already this or something similar error
> some time ago.
see e.g.
https://trac.osgeo.org/grass/ticket/1293
http://lists.osgeo.org/pipermail/grass-dev/2014-August/070469.html
https://trac.osgeo.org/grass/ticket/1856
https://trac.osgeo.org/grass/ticket/2532
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-7-0-1-tp5213369p5214208.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
