[GRASS-dev] [GRASS GIS] #2708: Run GRASS with Python3
GRASS GIS trac at osgeo.org
Mon Jul 20 01:33:37 PDT 2015
  Reporter:  zarch        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.1
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by zarch):
 Replying to [comment:1 glynn]:
 > Replying to [ticket:2708 zarch]:
 > > 3) lib/python/script/* => script.diff
 > These are wrong. You should be converting str to bytes, not the other
 way around.
 > A child process' argv, environment, stdin/stdout/stderr are all byte
 sequences.
 > Converting everything to unicode so that Python can convert it back to
 bytes under
 > the hood is adding needless failure modes.
 I agree with you, actually this was my first attempt, but then I have to
 face that the string formatting is available for bytes, only on python
 3.5, that it is not stable yet. therefore when I call
 make_command/run_command I got:
 In [1]: from grass.script import core as gcore
 In [2]: gcore.make_command('g.region', raster='elevation', flags='p')
 Out[2]: ['g.region', '-p', "raster=b'elevation'"]
 In [3]: gcore.run_command('g.region', raster='elevation', flags='p')
 WARNING: Illegal filename <b'elevation'>. Character <'> not allowed.
 ERROR: Raster map <b'elevation'> not found
 CalledModuleError                         Traceback (most recent call
 last)
 <ipython-input-5-c7b3927bef11> in <module>()
 ----> 1 gcore.run_command('g.region', raster='elevation', flags='p')
 /home/pietro/docdat/src/gis/grass71/dist.x86_64-unknown-linux-
 gnu/etc/python/grass/script/core.py in run_command(*args, **kwargs)
     403     ps = start_command(*args, **kwargs)
     404     returncode = ps.wait()
 --> 405     return handle_errors(returncode, returncode, args, kwargs)
     406
     407
 gnu/etc/python/grass/script/core.py in handle_errors(returncode, result,
 args, kwargs)
     321         args = make_command(*args, **kwargs)
     322         raise CalledModuleError(module=None, code=repr(args),
 --> 323                                 returncode=returncode)
     324
     325 def start_command(prog, flags="", overwrite=False, quiet=False,
 CalledModuleError: Module run None ['g.region', '-p',
 "raster=b'elevation'"] ended with error
 Process ended with non-zero return code 1. See errors in the (error)
 output.
 In [4]: "%s=%s" % (b'raster', b'elevation')
 Out[4]: "b'raster'=b'elevation'"
 In [5]: "%s=%s" % (b'raster'.decode(), b'elevation'.decode())
 Out[5]: 'raster=elevation'
 Do you have an idea on how we could/should fix this?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2708#comment:2>
