[GRASS-dev] [GRASS GIS] #2708: Run GRASS with Python3
trac at osgeo.org
Tue Jul 21 11:35:39 PDT 2015
Reporter: zarch | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:2 zarch]:
In [5]: "%s=%s" % (b'raster'.decode(), b'elevation'.decode())
Out[5]: 'raster=elevation'
> Do you have an idea on how we could/should fix this?
Just avoid using string formatting for such trivial cases, e.g.:
args.append(opt.encode('ascii') + b'=' + _make_val(val)
To be honest, converting grass.script to Python 3 isn't going to be much
fun, as a scripting library fundamentally revolves around dealing with
byte strings (command-line arguments, environment variables,
stdin/stdout), while Python 3 tries to pretend that byte strings are some
kind of low-level implementation detail in a world where everything is
Unicode.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2708#comment:3>
