[GRASS-dev] compiling on OSX 10.11 (El Capitan Beta)
Carlos Grohmann carlos.grohmann at gmail.com
Wed Jul 22 18:18:48 PDT 2015
Thanks, William.
That worked, at least for the configure part. Now the problem is at
compiling. At the end of make, I get a ton of errors in modules:
Errors in:
/Users/guano/Documents/installs/grass70_release/scripts/d.correlate
/Users/guano/Documents/installs/grass70_release/scripts/d.out.file
/Users/guano/Documents/installs/grass70_release/scripts/d.to.rast
/Users/guano/Documents/installs/grass70_release/scripts/d.polar
/Users/guano/Documents/installs/grass70_release/scripts/d.rast.edit
/Users/guano/Documents/installs/grass70_release/scripts/d.rast.leg
/Users/guano/Documents/installs/grass70_release/scripts/d.redraw
/Users/guano/Documents/installs/grass70_release/scripts/d.shade
/Users/guano/Documents/installs/grass70_release/scripts/d.what.rast
/Users/guano/Documents/installs/grass70_release/scripts/d.what.vect
/Users/guano/Documents/installs/grass70_release/scripts/db.dropcolumn
/Users/guano/Documents/installs/grass70_release/scripts/db.droptable
/Users/guano/Documents/installs/grass70_release/scripts/db.in.ogr
/Users/guano/Documents/installs/grass70_release/scripts/db.out.ogr
/Users/guano/Documents/installs/grass70_release/scripts/db.test
/Users/guano/Documents/installs/grass70_release/scripts/db.univar
/Users/guano/Documents/installs/grass70_release/scripts/g.extension
/Users/guano/Documents/installs/grass70_release/scripts/g.extension.all
/Users/guano/Documents/installs/grass70_release/scripts/g.manual
/Users/guano/Documents/installs/grass70_release/scripts/i.colors.enhance
/Users/guano/Documents/installs/grass70_release/scripts/i.image.mosaic
/Users/guano/Documents/installs/grass70_release/scripts/i.in.spotvgt
/Users/guano/Documents/installs/grass70_release/scripts/i.oif
/Users/guano/Documents/installs/grass70_release/scripts/i.pansharpen
/Users/guano/Documents/installs/grass70_release/scripts/i.spectral
/Users/guano/Documents/installs/grass70_release/scripts/i.tasscap
/Users/guano/Documents/installs/grass70_release/scripts/m.proj
/Users/guano/Documents/installs/grass70_release/scripts/r.blend
/Users/guano/Documents/installs/grass70_release/scripts/r.buffer.lowmem
/Users/guano/Documents/installs/grass70_release/scripts/r.colors.stddev
/Users/guano/Documents/installs/grass70_release/scripts/r.fillnulls
/Users/guano/Documents/installs/grass70_release/scripts/r.grow
/Users/guano/Documents/installs/grass70_release/scripts/r.in.aster
/Users/guano/Documents/installs/grass70_release/scripts/r.in.srtm
/Users/guano/Documents/installs/grass70_release/scripts/r.in.wms
/Users/guano/Documents/installs/grass70_release/scripts/r.mask
/Users/guano/Documents/installs/grass70_release/scripts/r.out.xyz
/Users/guano/Documents/installs/grass70_release/scripts/r.pack
/Users/guano/Documents/installs/grass70_release/scripts/r.plane
/Users/guano/Documents/installs/grass70_release/scripts/r.reclass.area
/Users/guano/Documents/installs/grass70_release/scripts/r.rgb
/Users/guano/Documents/installs/grass70_release/scripts/r.shade
/Users/guano/Documents/installs/grass70_release/scripts/r.tileset
/Users/guano/Documents/installs/grass70_release/scripts/r.unpack
/Users/guano/Documents/installs/grass70_release/scripts/r3.in.xyz
/Users/guano/Documents/installs/grass70_release/scripts/v.build.all
/Users/guano/Documents/installs/grass70_release/scripts/v.centroids
/Users/guano/Documents/installs/grass70_release/scripts/v.db.addcolumn
/Users/guano/Documents/installs/grass70_release/scripts/v.db.addtable
/Users/guano/Documents/installs/grass70_release/scripts/v.db.join
/Users/guano/Documents/installs/grass70_release/scripts/v.db.dropcolumn
/Users/guano/Documents/installs/grass70_release/scripts/v.db.droprow
/Users/guano/Documents/installs/grass70_release/scripts/v.db.droptable
/Users/guano/Documents/installs/grass70_release/scripts/v.db.renamecolumn
/Users/guano/Documents/installs/grass70_release/scripts/v.db.reconnect.all
/Users/guano/Documents/installs/grass70_release/scripts/v.db.univar
/Users/guano/Documents/installs/grass70_release/scripts/v.db.update
/Users/guano/Documents/installs/grass70_release/scripts/v.dissolve
/Users/guano/Documents/installs/grass70_release/scripts/v.in.e00
/Users/guano/Documents/installs/grass70_release/scripts/v.in.geonames
/Users/guano/Documents/installs/grass70_release/scripts/v.in.lines
/Users/guano/Documents/installs/grass70_release/scripts/v.in.mapgen
/Users/guano/Documents/installs/grass70_release/scripts/v.in.wfs
/Users/guano/Documents/installs/grass70_release/scripts/v.rast.stats
/Users/guano/Documents/installs/grass70_release/scripts/v.report
/Users/guano/Documents/installs/grass70_release/scripts/v.pack
/Users/guano/Documents/installs/grass70_release/scripts/v.to.lines
/Users/guano/Documents/installs/grass70_release/scripts/v.unpack
/Users/guano/Documents/installs/grass70_release/scripts/v.what.strds
/Users/guano/Documents/installs/grass70_release/scripts/v.what.vect
/Users/guano/Documents/installs/grass70_release/scripts/wxpyimgview
/Users/guano/Documents/installs/grass70_release/scripts/v.krige
/Users/guano/Documents/installs/grass70_release/temporal/t.create
/Users/guano/Documents/installs/grass70_release/temporal/t.support
/Users/guano/Documents/installs/grass70_release/temporal/t.topology
/Users/guano/Documents/installs/grass70_release/temporal/t.list
/Users/guano/Documents/installs/grass70_release/temporal/t.info
/Users/guano/Documents/installs/grass70_release/temporal/t.merge
/Users/guano/Documents/installs/grass70_release/temporal/t.remove
/Users/guano/Documents/installs/grass70_release/temporal/t.sample
/Users/guano/Documents/installs/grass70_release/temporal/t.register
/Users/guano/Documents/installs/grass70_release/temporal/t.unregister
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.accumulate
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.accdetect
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.aggregate
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.aggregate.ds
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.colors
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.to.rast3
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.univar
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.list
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.mapcalc
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.neighbors
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.series
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.export
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.out.vtk
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.import
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.gapfill
/Users/guano/Documents/installs/grass70_release/temporal/t.rast.extract
/Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.list
/Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.extract
/Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.mapcalc
/Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.univar
/Users/guano/Documents/installs/grass70_release/temporal/t.rename
/Users/guano/Documents/installs/grass70_release/temporal/t.select
/Users/guano/Documents/installs/grass70_release/temporal/t.snap
/Users/guano/Documents/installs/grass70_release/temporal/t.shift
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.list
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.db.select
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.export
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.extract
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.import
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.what.strds
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.observe.strds
/Users/guano/Documents/installs/grass70_release/temporal/t.vect.univar
/Users/guano/Documents/installs/grass70_release/gui/wxpython/animation
/Users/guano/Documents/installs/grass70_release/gui/wxpython/mapswipe
/Users/guano/Documents/installs/grass70_release/gui/wxpython/gmodeler
/Users/guano/Documents/installs/grass70_release/gui/wxpython/rlisetup
/Users/guano/Documents/installs/grass70_release/gui/wxpython/psmap
/Users/guano/Documents/installs/grass70_release/gui/wxpython/dbmgr
/Users/guano/Documents/installs/grass70_release/gui/wxpython/vdigit
/Users/guano/Documents/installs/grass70_release/gui/wxpython/iclass
/Users/guano/Documents/installs/grass70_release/gui/wxpython/gcp
/Users/guano/Documents/installs/grass70_release/gui/wxpython/timeline
/Users/guano/Documents/installs/grass70_release/visualization/wximgview
the first script, d.correlate, gives me this eror:
cd scripts/d.correlate/
GuanoAFBIOTA:d.correlate guano$ make
if [
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
!= "" ] ; then
GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
d.correlate.tmp.html ; fi
dyld: Library not loaded:
/Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
  Referenced from:
/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
  Reason: image not found
make: *** [d.correlate.tmp.html] Error 1
rm d.correlate.tmp.html
the first temporal module, t.create, this one (just last part of output):
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/t.vect.univar",
line 66, in <module>
    import grass.temporal as tgis
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/__init__.py",
line 1, in <module>
    from core import *
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/core.py",
line 38, in <module>
    from c_libraries_interface import *
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/c_libraries_interface.py",
line 19, in <module>
    import grass.lib.gis as libgis
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/lib/gis.py",
line 23, in <module>
    _libs["grass_gis.7.0.1svn"] = load_library("grass_gis.7.0.1svn")
  File
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/lib/ctypes_loader.py",
line 57, in load_library
    raise ImportError,"%s not found." % libname
ImportError: grass_gis.7.0.1svn not found.
make[1]: *** [t.vect.univar.tmp.html] Error 1
rm t.vect.univar.tmp.html
The gui modules also give an error similar to d.correlate, so something is
referencing grass_gis.7.0.1svn instead of the current release.
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150722/63e052a9/attachment-0001.html>
