[GRASS-dev] compiling on OSX 10.11 (El Capitan Beta)
William Kyngesburye
woklist at kyngchaos.com
Wed Jul 22 20:09:16 PDT 2015
I don't see any GDAL problem there. It looks like DYLD_LIBRARY_PATH is not working when running the modules to create documentation.
I don't know where to go from there.
On Jul 22, 2015, at 8:18 PM, Carlos Grohmann <carlos.grohmann at gmail.com> wrote:
> Thanks, William.
> That worked, at least for the configure part. Now the problem is at compiling. At the end of make, I get a ton of errors in modules:
> Errors in:
> /Users/guano/Documents/installs/grass70_release/scripts/d.correlate
> /Users/guano/Documents/installs/grass70_release/scripts/d.out.file
> /Users/guano/Documents/installs/grass70_release/scripts/d.to.rast
> /Users/guano/Documents/installs/grass70_release/scripts/d.polar
> /Users/guano/Documents/installs/grass70_release/scripts/d.rast.edit
> /Users/guano/Documents/installs/grass70_release/scripts/d.rast.leg
> /Users/guano/Documents/installs/grass70_release/scripts/d.redraw
> /Users/guano/Documents/installs/grass70_release/scripts/d.shade
> /Users/guano/Documents/installs/grass70_release/scripts/d.what.rast
> /Users/guano/Documents/installs/grass70_release/scripts/d.what.vect
> /Users/guano/Documents/installs/grass70_release/scripts/db.dropcolumn
> /Users/guano/Documents/installs/grass70_release/scripts/db.droptable
> /Users/guano/Documents/installs/grass70_release/scripts/db.in.ogr
> /Users/guano/Documents/installs/grass70_release/scripts/db.out.ogr
> /Users/guano/Documents/installs/grass70_release/scripts/db.test
> /Users/guano/Documents/installs/grass70_release/scripts/db.univar
> /Users/guano/Documents/installs/grass70_release/scripts/g.extension
> /Users/guano/Documents/installs/grass70_release/scripts/g.extension.all
> /Users/guano/Documents/installs/grass70_release/scripts/g.manual
> /Users/guano/Documents/installs/grass70_release/scripts/i.colors.enhance
> /Users/guano/Documents/installs/grass70_release/scripts/i.image.mosaic
> /Users/guano/Documents/installs/grass70_release/scripts/i.in.spotvgt
> /Users/guano/Documents/installs/grass70_release/scripts/i.oif
> /Users/guano/Documents/installs/grass70_release/scripts/i.pansharpen
> /Users/guano/Documents/installs/grass70_release/scripts/i.spectral
> /Users/guano/Documents/installs/grass70_release/scripts/i.tasscap
> /Users/guano/Documents/installs/grass70_release/scripts/m.proj
> /Users/guano/Documents/installs/grass70_release/scripts/r.blend
> /Users/guano/Documents/installs/grass70_release/scripts/r.buffer.lowmem
> /Users/guano/Documents/installs/grass70_release/scripts/r.colors.stddev
> /Users/guano/Documents/installs/grass70_release/scripts/r.fillnulls
> /Users/guano/Documents/installs/grass70_release/scripts/r.grow
> /Users/guano/Documents/installs/grass70_release/scripts/r.in.aster
> /Users/guano/Documents/installs/grass70_release/scripts/r.in.srtm
> /Users/guano/Documents/installs/grass70_release/scripts/r.in.wms
> /Users/guano/Documents/installs/grass70_release/scripts/r.mask
> /Users/guano/Documents/installs/grass70_release/scripts/r.out.xyz
> /Users/guano/Documents/installs/grass70_release/scripts/r.pack
> /Users/guano/Documents/installs/grass70_release/scripts/r.plane
> /Users/guano/Documents/installs/grass70_release/scripts/r.reclass.area
> /Users/guano/Documents/installs/grass70_release/scripts/r.rgb
> /Users/guano/Documents/installs/grass70_release/scripts/r.shade
> /Users/guano/Documents/installs/grass70_release/scripts/r.tileset
> /Users/guano/Documents/installs/grass70_release/scripts/r.unpack
> /Users/guano/Documents/installs/grass70_release/scripts/r3.in.xyz
> /Users/guano/Documents/installs/grass70_release/scripts/v.build.all
> /Users/guano/Documents/installs/grass70_release/scripts/v.centroids
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.addcolumn
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.addtable
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.join
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.dropcolumn
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.droprow
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.droptable
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.renamecolumn
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.reconnect.all
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.univar
> /Users/guano/Documents/installs/grass70_release/scripts/v.db.update
> /Users/guano/Documents/installs/grass70_release/scripts/v.dissolve
> /Users/guano/Documents/installs/grass70_release/scripts/v.in.e00
> /Users/guano/Documents/installs/grass70_release/scripts/v.in.geonames
> /Users/guano/Documents/installs/grass70_release/scripts/v.in.lines
> /Users/guano/Documents/installs/grass70_release/scripts/v.in.mapgen
> /Users/guano/Documents/installs/grass70_release/scripts/v.in.wfs
> /Users/guano/Documents/installs/grass70_release/scripts/v.rast.stats
> /Users/guano/Documents/installs/grass70_release/scripts/v.report
> /Users/guano/Documents/installs/grass70_release/scripts/v.pack
> /Users/guano/Documents/installs/grass70_release/scripts/v.to.lines
> /Users/guano/Documents/installs/grass70_release/scripts/v.unpack
> /Users/guano/Documents/installs/grass70_release/scripts/v.what.strds
> /Users/guano/Documents/installs/grass70_release/scripts/v.what.vect
> /Users/guano/Documents/installs/grass70_release/scripts/wxpyimgview
> /Users/guano/Documents/installs/grass70_release/scripts/v.krige
> /Users/guano/Documents/installs/grass70_release/temporal/t.create
> /Users/guano/Documents/installs/grass70_release/temporal/t.support
> /Users/guano/Documents/installs/grass70_release/temporal/t.topology
> /Users/guano/Documents/installs/grass70_release/temporal/t.list
> /Users/guano/Documents/installs/grass70_release/temporal/t.info
> /Users/guano/Documents/installs/grass70_release/temporal/t.merge
> /Users/guano/Documents/installs/grass70_release/temporal/t.remove
> /Users/guano/Documents/installs/grass70_release/temporal/t.sample
> /Users/guano/Documents/installs/grass70_release/temporal/t.register
> /Users/guano/Documents/installs/grass70_release/temporal/t.unregister
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.accumulate
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.accdetect
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.aggregate
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.aggregate.ds
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.colors
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.to.rast3
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.univar
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.list
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.mapcalc
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.neighbors
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.series
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.export
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.out.vtk
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.import
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.gapfill
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast.extract
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.list
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.extract
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.mapcalc
> /Users/guano/Documents/installs/grass70_release/temporal/t.rast3d.univar
> /Users/guano/Documents/installs/grass70_release/temporal/t.rename
> /Users/guano/Documents/installs/grass70_release/temporal/t.select
> /Users/guano/Documents/installs/grass70_release/temporal/t.snap
> /Users/guano/Documents/installs/grass70_release/temporal/t.shift
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.list
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.db.select
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.export
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.extract
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.import
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.what.strds
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.observe.strds
> /Users/guano/Documents/installs/grass70_release/temporal/t.vect.univar
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/animation
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/mapswipe
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/gmodeler
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/rlisetup
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/psmap
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/dbmgr
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/vdigit
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/iclass
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/gcp
> /Users/guano/Documents/installs/grass70_release/gui/wxpython/timeline
> /Users/guano/Documents/installs/grass70_release/visualization/wximgview
> the first script, d.correlate, gives me this eror:
> cd scripts/d.correlate/
> GuanoAFBIOTA:d.correlate guano$ make
> if [ "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate" != "" ] ; then GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70 GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0 PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH" PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:" LC_ALL=C /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate --html-description < /dev/null | grep -v '</body>\|</html>' > d.correlate.tmp.html ; fi
> dyld: Library not loaded: /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
> Referenced from: /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> Reason: image not found
> make: *** [d.correlate.tmp.html] Error 1
> rm d.correlate.tmp.html
> the first temporal module, t.create, this one (just last part of output):
> Traceback (most recent call last):
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/t.vect.univar", line 66, in <module>
> import grass.temporal as tgis
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/__init__.py", line 1, in <module>
> from core import *
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/core.py", line 38, in <module>
> from c_libraries_interface import *
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/temporal/c_libraries_interface.py", line 19, in <module>
> import grass.lib.gis as libgis
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/lib/gis.py", line 23, in <module>
> _libs["grass_gis.7.0.1svn"] = load_library("grass_gis.7.0.1svn")
> File "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python/grass/lib/ctypes_loader.py", line 57, in load_library
> raise ImportError,"%s not found." % libname
> ImportError: grass_gis.7.0.1svn not found.
> make[1]: *** [t.vect.univar.tmp.html] Error 1
> rm t.vect.univar.tmp.html
> The gui modules also give an error similar to d.correlate, so something is referencing grass_gis.7.0.1svn instead of the current release.
> thanks
> Carlos
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
