[GRASS-dev] Travis CI
Ivan Mincik
ivan.mincik at gmail.com
Mon Jul 27 08:23:34 PDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 23.07.2015 10:42, Rainer M Krug wrote:
> Ivan Minčík <ivan.mincik at gmail.com> writes:
>> Hi all, we have just integrated Travis Continuous Integration
>> system [1] to the GRASS source code. Every commit is now build in
>> Travis [2] using gcc and clang. In case the build fails, error
>> message should go to GRASS-dev list.
> This looks very nice - great. But I see it only =compiles under
> Linux.
> I have a .travis.yml [1] and a homebrew formula [2] to install 7.1
> from head under OSX which is also running the tests (although the
> test are not running at the moment - I have to investigate why).
> I would suggest to merge the check for Mac into your .travis.yml so
> that Mac builds are also checked automatically.
Looks like a good idea, but I have no experience with Mac development.
Ivan Minčík
ivan.mincik at gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJVtkz2AAoJEPfdLsR5Upoej+gH/jW+KfMCElgJkIwQ+4q6H19G
FoRcWu3zyjh28isGO2ht8RYMd473zHMQv9ydiTamNUKeraLvWX7ELcpT0dUw+N56
jyV3I+xJPT+Fq938h/E7UOkeYnzc5Q3pdrKqf8+VTjMrKDPHxmWZMBwb/M5KbSNp
Wg3eM1s+v9Nl0tYncSWtxdG6r1GB8Np3Kt5l9HY5RzyO/3NbXl1nZdIM4W7FFVrY
WkMw7qwLfNhvPJZjt09itrjSm82C4KF4cCChJuBLYbZwe+kxZYqyDs4Yl/8OjPTL
nRMhRqg8vV18q6Ri5l+F5wgLwRm1qpLtyT569z4ZqG7lisochW1/LTMsM//sfAA=
=YP7r
-----END PGP SIGNATURE-----
