[GRASS-dev] Travis CI
Rainer M Krug
Rainer at krugs.de
Tue Jul 28 06:34:24 PDT 2015
Markus Neteler <neteler at osgeo.org> writes:
> Hi Rainer,
> On Jul 28, 2015 10:11 AM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>> Ivan Mincik <ivan.mincik at gmail.com> writes:
>> I am using homebrew, a package manager for OSX. This simplifies the
>> compilation significantly as it takes care of all dependencies. So the
>> installation script (called recipe) is at [1] and adapted from the 7.0
>> of osgeo4mac [2].
>> The travis script uses my recipe from [1] and installs GRASS 7.1 from
>> HEAD. I'll walk you quickly through the .travis.yml at [3]:
> Maybe these explanations should go into a wiki or trac page? To not get
> lost?
I would be happy to write the installation steps down for GRASS for OSX
using homebrew with the recipe in my repository.
If you tell me where (on which page in the wiki or on a new page?), I could probably add it this evening - Oh -
do I need write access to the wiki?
Thanks,
Rainer
> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150728/63001906/attachment.pgp>
