[GRASS-dev] Travis CI
Rainer M Krug Rainer at krugs.de
Tue Jul 28 06:39:33 PDT 2015
Rainer M Krug <Rainer at krugs.de> writes:
> Markus Neteler <neteler at osgeo.org> writes:
>> Hi Rainer,
>> On Jul 28, 2015 10:11 AM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>>> Ivan Mincik <ivan.mincik at gmail.com> writes:
>>> I am using homebrew, a package manager for OSX. This simplifies the
>>> compilation significantly as it takes care of all dependencies. So the
>>> installation script (called recipe) is at [1] and adapted from the 7.0
>>> of osgeo4mac [2].
>>> The travis script uses my recipe from [1] and installs GRASS 7.1 from
>>> HEAD. I'll walk you quickly through the .travis.yml at [3]:
>> Maybe these explanations should go into a wiki or trac page? To not get
>> lost?
> I would be happy to write the installation steps down for GRASS for OSX
> using homebrew with the recipe in my repository.
> If you tell me where (on which page in the wiki or on a new page?), I could probably add it this evening - Oh -
> do I need write access to the wiki?
Would http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX be
appropriate? It seems that I can just edit it and do not need special
access there?
Rainer
> Thanks,
> Rainer
>> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150728/dc88d6dd/attachment-0001.pgp>
