[GRASS-dev] r65348 (GRASS_TMPDIR_MAPSET)
Thu Jun 4 07:08:12 PDT 2015
Martin Landa wrote:
> > Yes. I'd prefer that lib/raster continues to create the file on the
> > same filesystem as the mapset and atomically rename()s it into place.
> > IOW, the new tempfile behaviour needs to be availble in addition to
> > the long-standing behaviour, not a replacement for it.
> this is controlled by GRASS_TMPDIR_MAPSET variable, if not set the
> default is the long-standing behaviour.
The the temporary files used by lib/raster need to be on the same
filesystem as the mapset regardless of any environment settings.
