[GRASS-dev] r65348 (GRASS_TMPDIR_MAPSET)
Martin Landa landa.martin at gmail.com
Thu Jun 4 07:30:18 PDT 2015
2015-06-04 16:08 GMT+02:00 Glynn Clements <glynn at gclements.plus.com>:
> The the temporary files used by lib/raster need to be on the same
> filesystem as the mapset regardless of any environment settings.
please could you write us why? I didn't find any problem (bearing in
mind changes in G_rename_file() which tries to rename file and if
fails copy & remove). Anyway, I wonder how to treat raster lib and
vector lib differently. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
