[GRASS-dev] GRASS GIS 7.0.1 planning: potential backports
Vaclav Petras wenzeslaus at gmail.com
Tue Jun 9 13:21:18 PDT 2015
What is the status of r65057, #2626, and #2655?
In 70 release branch, I'm not able to use PostgreSQL attribute table but it
works in trunk. I think that this is thanks to r65057. The bug was probably
also reason for encountering #2626.
Thanks,
Vaclav
db.login + pg & mysql driver: support hostname and port
https://trac.osgeo.org/grass/changeset/65057
v.out.ogr does not suggest db.connect and db.login when not set
http://trac.osgeo.org/grass/ticket/2626
update t.connect to use db.login host= port=
https://trac.osgeo.org/grass/ticket/2655
[GRASS-dev] [GRASS-SVN] r65057 - in grass/trunk/db: db.login drivers/mysql
drivers/postgres
http://lists.osgeo.org/pipermail/grass-commit/2015-April/035962.html
http://lists.osgeo.org/pipermail/grass-dev/2015-April/074808.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150609/1369bd1c/attachment.html>
