[GRASS-dev] GRASS GIS 7.0.1 planning: potential backports
Markus Neteler neteler at osgeo.org
Fri Jun 12 07:14:14 PDT 2015
On Tue, Jun 9, 2015 at 10:21 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> What is the status of r65057, #2626, and #2655?
I have added it to
https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.1tobebackported
It would be important to get RC1 asap out.
Markus
> In 70 release branch, I'm not able to use PostgreSQL attribute table but it
> works in trunk. I think that this is thanks to r65057. The bug was probably
> also reason for encountering #2626.
> Thanks,
> Vaclav
> db.login + pg & mysql driver: support hostname and port
> https://trac.osgeo.org/grass/changeset/65057
> v.out.ogr does not suggest db.connect and db.login when not set
> http://trac.osgeo.org/grass/ticket/2626
> update t.connect to use db.login host= port=
> https://trac.osgeo.org/grass/ticket/2655
> [GRASS-dev] [GRASS-SVN] r65057 - in grass/trunk/db: db.login drivers/mysql
> drivers/postgres
> http://lists.osgeo.org/pipermail/grass-commit/2015-April/035962.html
> http://lists.osgeo.org/pipermail/grass-dev/2015-April/074808.html
