[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
trac at osgeo.org
Wed Jun 10 09:42:56 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
CPU: Unspecified | Platform: MSWindows 8
Comment (by wenzeslaus):
Replying to [comment:14 wenzeslaus]:
> Replying to [comment:13 hellik]:
> > Replying to [comment:12 annakrat]:
> > > I made a screencast to see what's in the terminal which just flashes
during the installation. I get:
> ERROR: GISRC - variable not set
> > > This is the same what happens if you run run_gmkfontcap from windows
command prompt.
> > relevant lines of codes
[http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
Installer.nsi.tmpl#L531 g.mkfontcap] and following.
> 546 FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
> 547 FileWrite $0 '$\r$\n'
> 548 FileWrite $0 'rem set path to freetype dll$\r$\n'
> 549 FileWrite $0 'set
FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
> 550 FileWrite $0 '$\r$\n'
> 551 FileWrite $0 'rem set dependecies path$\r$\n'
> 552 FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
> > any idea which variable isn't set?
> It is the [http://grass.osgeo.org/grass70/manuals/variables.html#list-
of-selected-%28grass-related%29-shell-environment-variables GISRC]
variable which is not set.
> We could perhaps avoid this problem altogether if we would just tell
GRASS GIS what to run (#2579),
After r65252 and r65294 (see #2579) you can use (in trunk, upcoming 7.1
release):
C:\path\to\grass C:\path\to\demomapset --exec g.mkfontcap
This should run `g.mkfontcap` in a regular GRASS session but without
touching user's GRASS rc file in home directory (if it does, it's a bug),
so the last used Mapset will be still whatever user or installer sets.
> although this might have its own problems during installation.
GRASS is installed, right? So this should work in theory.
> One other thing is that it is not clear to me what changed that now
GISRC variable is required but it was not before.
Let's say that we don't need to deal with this because it is expected that
GRASS module requires `GISRC` to be set. I'm just not sure why it is
expected by `g.mkfontcap` (probably it calls some GRASS library
functions).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:16>
