[GRASS-dev] [GRASS GIS] #2692: v.in.ascii does not handle text in qoutes
GRASS GIS trac at osgeo.org
Wed Jun 10 12:10:49 PDT 2015
 Reporter:  wenzeslaus                           |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:  7.0.1
Component:  Default                              |    Version:  svn-trunk
 Keywords:  CSV, doublequote, singlequote, text  |        CPU:  Unspecified
  delimiter                                      |
 Platform:  Unspecified                          |
 Since r63581 G7:v.in.ascii should be able to handle "CSV with quoted text
 fields" (`text` option) but the quotes are stored to the database. This is
 the result from `v.db.select` (same thing in `sqliteman`):
 100|437343.6704|4061363.41525|"High Erosion"|"Low Deposition"
 To reproduce, run:
 $ cd grass/src
 $ ./bin.../grass71 ... -text
 > cd vector/v.in.ascii/testsuite/
 > python test_csv.py
 I added these tests in r65426 and r65427 if you wish to review them.
 `G_tokenize2()` results online:
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-06-10-07-00/report_for_nc_spm_08_grass7_nc/lib/gis/gis_lib_tokenize/index.html
 `v.in.ascii` results online:
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-06-10-07-00/report_for_nc_spm_08_grass7_nc/vector/v.in.ascii/test_csv/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2692>
