[GRASS-dev] [GRASS GIS] #2687: r.info picks map from current Mapset instead of PERMANENT
trac at osgeo.org
Wed Jun 10 12:42:04 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: fixed | Keywords: r.info, mapset, search path,
| PERMANENT
CPU: x86-64 | Platform: Linux
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 martinl]:
> Try r65437
Thanks, r65437 fixed the issue. Closing.
If somebody wants to test quickly, it can be tested for example with
(`r.info` is used there):
# inside GRASS session in NC SPM
cd ./lib/python/gunittest/testsuite/
python test_module_assertions.py
Just for the record, the missing `G_file_name(path, element, name,
mapset);` call originated in r65348.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:4>
