[GRASS-dev] [GRASS GIS] #2687: r.info picks map from current Mapset instead of PERMANENT
GRASS GIS trac at osgeo.org
Thu Jun 11 06:56:37 PDT 2015
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  7.1.0
 Component:  Raster      |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  r.info, mapset, search path,
                         |  PERMANENT
       CPU:  x86-64      |   Platform:  Linux
Comment (by glynn):
 Replying to [comment:3 martinl]:
 > Try r65437
 Does the write case need something similar?
 More generally, why is "path" being constructed before the mapset has been
 determined?
 Bear in mind that fully qualified names are valid for output files so long
 as the mapset is the current mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:5>
