[GRASS-dev] [GRASS GIS] #2687: r.info picks map from current Mapset instead of PERMANENT
GRASS GIS trac at osgeo.org
Fri Jun 12 14:41:49 PDT 2015
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  7.1.0
 Component:  Raster      |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  r.info, mapset, search path,
                         |  PERMANENT
       CPU:  x86-64      |   Platform:  Linux
Comment (by martinl):
 Replying to [comment:5 glynn]:
 > Does the write case need something similar?
 > More generally, why is "path" being constructed before the mapset has
 been determined?
 right, it was not good idea, changed in r65453
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:6>
