[GRASS-dev] temporal modules cannot open database
Sören Gebbert
soerengebbert at googlemail.com
Thu Jun 11 12:54:19 PDT 2015
Hi Luca,
i did not change the database structure of the temporal framework recently.
The exception seems to be from the sqlite3 backend, hence it should
not be related to different temporal database formats.
Can you access the database with the sqlite3 command directly?
sqlite3 /grassdata/latlong/ecad100_climate/tgis/sqlite.db
Best regards
Soeren
2015-06-11 15:14 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> Hi devs,
> I have problem to open the temporal database (with grass70svn and grass71)
> t.list
> ERROR: Unable to connect to sqlite3 database:
> Exception: "unable to open database file"
> Please use t.connect to set a read- and writable temporal database backend
> permissions on the file seems to be correct,
> ls -lh /grassdata/latlong/ecad100_climate/tgis/
> totale 49M
> -rw-r--r-- 1 lucadelu gis 49M set 3 2014 sqlite.db
> Were there any changes in the temporal code that doesn't recognize the
> old database structure?
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
