[GRASS-dev] temporal modules cannot open database
Luca Delucchi
lucadeluge at gmail.com
Thu Jun 11 23:07:04 PDT 2015
On 11 June 2015 at 21:54, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren,
> i did not change the database structure of the temporal framework recently.
> The exception seems to be from the sqlite3 backend, hence it should
> not be related to different temporal database formats.
> Can you access the database with the sqlite3 command directly?
> sqlite3 /grassdata/latlong/ecad100_climate/tgis/sqlite.db
yes, I can see the tables and they seems coming from a temporal dataset :-)
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
