[GRASS-dev] temporal modules cannot open database
Sören Gebbert soerengebbert at googlemail.com
Wed Jun 24 15:05:28 PDT 2015
Hi Luca,
is it possible that the path to the location has changed or that the
location was renamed?
Best regards
Soeren
2015-06-12 8:07 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> On 11 June 2015 at 21:54, Sören Gebbert <soerengebbert at googlemail.com> wrote:
>> Hi Luca,
> Hi Soeren,
>> i did not change the database structure of the temporal framework recently.
>> The exception seems to be from the sqlite3 backend, hence it should
>> not be related to different temporal database formats.
>> Can you access the database with the sqlite3 command directly?
>> sqlite3 /grassdata/latlong/ecad100_climate/tgis/sqlite.db
> yes, I can see the tables and they seems coming from a temporal dataset :-)
>> Best regards
>> Soeren
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
