[GRASS-dev] [GRASS GIS] #2694: rendering command layer and adding 3d raster layer broken
trac at osgeo.org
Fri Jun 12 13:46:50 PDT 2015
Reporter: annakrat | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: rendering
CPU: Unspecified | Platform: Linux
Comment (by annakrat):
Replying to [comment:1 martinl]:
> Replying to [ticket:2694 annakrat]:
> > 1. adding 3D raster layer breaks rendering, although there is no
error, rendering just stops working after that and busy cursors stays
there. I was trying to fix this one, but was not able to get rid of the
progress bar which was still showing up:
> please try out r65450
Thank you, works nicely
> > 2. Rendering command layers is weird, (un)checking has no effect.
> I would suggest to remove command layers from wxGUI completely, what do
you think?
Hm, I was actually using it. For example you can have multiple legends
with command layers and you can save them to workspace. But that's
workaround for not having a way to display multiple legends.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:3>
