[GRASS-dev] [GRASS GIS] #2694: rendering command layer and adding 3d raster layer broken
trac at osgeo.org
Fri Jun 12 13:52:50 PDT 2015
Reporter: annakrat | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: rendering
CPU: Unspecified | Platform: Linux
Comment (by annakrat):
Replying to [comment:3 annakrat]:
> > I would suggest to remove command layers from wxGUI completely, what
do you think?
> Hm, I was actually using it. For example you can have multiple legends
with command layers and you can save them to workspace. But that's
workaround for not having a way to display multiple legends.
I realized d.histogram is not working when called from Map Display
toolbar. It seems that it actually uses the command layers.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:4>
