[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
trac at osgeo.org
Fri Jun 12 14:15:30 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
CPU: Unspecified | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:22 annakrat]:
> I added the dummy GISRC in r65440 to installer. I tested it by changing
the already generated bat file and that seemed to work.
tested locally here in a simple windows command line (outside any winGRASS
session, not in a OSGeo4W-command line):
C:\Users\xxxx>set GISBASE=C:\OSGeo4W_use\apps\grass\grass-7.0.0
C:\Users\xxxx>set
FREETYPEBASE=C:\OSGeo4W_use\bin;C:\OSGeo4W_use\apps\msys\bin;C:\OSGeo4W_use\apps\grass\grass-7.0.0\lib
C:\Users\xxxx>set PATH=%FREETYPEBASE%;%PATH%
C:\Users\xxxx>set GISRC=dummy
C:\Users\xxxx>"%GISBASE%\bin\g.mkfontcap.exe" -o
+1 for backporting
it works
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:23>
