[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Fri Jun 12 14:22:57 PDT 2015
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.1
 Component:  Display      |    Version:  7.0.0
Resolution:               |   Keywords:  font, text, legend, scale bar
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by annakrat):
 Replying to [comment:23 hellik]:
 > Replying to [comment:22 annakrat]:
 > > I added the dummy GISRC in r65440 to installer. I tested it by
 changing the already generated bat file and that seemed to work.
 > tested locally here in a simple windows command line (outside any
 winGRASS session, not in a OSGeo4W-command line):
 > C:\Users\xxxx>set GISBASE=C:\OSGeo4W_use\apps\grass\grass-7.0.0
 > C:\Users\xxxx>set
 FREETYPEBASE=C:\OSGeo4W_use\bin;C:\OSGeo4W_use\apps\msys\bin;C:\OSGeo4W_use\apps\grass\grass-7.0.0\lib
 > C:\Users\xxxx>set PATH=%FREETYPEBASE%;%PATH%
 > C:\Users\xxxx>set GISRC=dummy
 > C:\Users\xxxx>"%GISBASE%\bin\g.mkfontcap.exe" -o
 > +1 for backporting
 > it works
 Done in r65452. Thanks. I will close it for now, we can reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:24>
