[GRASS-dev] All Python addons are missing
Vaclav Petras wenzeslaus at gmail.com
Sun Jun 14 05:00:00 PDT 2015
On Sun, Jun 14, 2015 at 7:01 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Sun, Jun 14, 2015 at 6:43 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Jun 14, 2015 at 12:40 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > If you want to avoid problems run `make distclean` before
>> > `svn up`. For automated builds this is necessary.
>> Sure, I have "make distclean" in for years. Yet not sufficient if the
>> failing file is not defined as clean target. This rarely happens but
>> this time it did.
> I apparently learn it from you [1]. However, the build for automated tests
> did not fail with the setup.py change, so how is that possible? setup.py
> was supposed to be in the OBJ file [2] if I understand the Makefile
> correctly.
As I'm thinking about it I would say that I have seen setup.py in the
script dir, not script/.OBJ..., so the Makefile might have been wrong
(which explains why it fails for you, but it does not explain why it worked
for me, and this doesn't ensure that it won't happen again).
> [1] http://lists.osgeo.org/pipermail/grass-dev/2014-September/070986.html
> [1 nabble]
> http://osgeo-org.1560.x6.nabble.com/SVN-trunk-issue-with-g-list-and-g-remove-and-solution-td5164890.html
> [2]
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/Makefile?rev=62097
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150614/416c2339/attachment.html>
