[GRASS-dev] [GRASS GIS] #2579: Specify command to be exectued as parameter of grass command
trac at osgeo.org
Sun Jun 14 15:37:04 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.1.0
Component: Startup | Version: svn-trunk
Resolution: fixed | Keywords: batch job, GRASS_BATCH_JOB, init
CPU: Unspecified | Platform: All
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Parsing of parameters should be refactored and improved and behavior when
both `GRASS_BATCH_JOB` and `--exec` are used should be revised but the
goal of this ticket was fulfilled. Closing as fixed. This shouldn't be
backported to 7.0 branch (or at lease not any time soon) because it makes
a lot of changes to a crucial code.
Two other major issues were discussed together with this topic and these
are //direct execution with imports// (`grass run r.slope.aspect
elevation=file:///path/to/file.tiff...`) and //subcommand interface//
(`grass start .../mapset; grass run r.slope.aspect...;`). The later should
be easy to implement now. The hardest part in implementation is to read
the "gisrc" file from current directory and decide the name for the `run`
subcommand considering newly added `--exec` and potential //direct
execution with imports// which would probably need another subcommand or
parameter. How to call individual interfaces (including this one) should
be revised as well.
There is an unresolved issue with code duplication between
`lib/init/grass.py` and `lib/python/script/setup.py`. There is some code
duplication now but `script.setup(.init)` would benefit from some code in
`grass.py` which would even increase the duplication. The question is if
we can safely import `grass.script.setup` during startup in `grass.py`.
Finally, to make this `--exec` interface really convenient (and script
universal), it would be nice to ensure that on system there is `grass`
available on path. This is true for Linux distributions but it is not true
for MS Windows. Perhaps it also needs to be documented more including
distinction between `grass`, `grass7` and `grass71`.
None of the issues above has currently its ticket.
//Direct execution with imports// GSoC idea:
* wiki:GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
//Subcommand interface// mailing list discussions:
* [http://lists.osgeo.org/pipermail/grass-user/2015-June/072525.html
Announcing new command line interface of `grass` program in trunk
(Vaclav)]
* [http://lists.osgeo.org/pipermail/grass-user/2015-June/072529.html
(Rainer)]
* [http://lists.osgeo.org/pipermail/grass-user/2015-June/072531.html
(Vaclav)]
* [http://lists.osgeo.org/pipermail/grass-user/2015-June/072537.html
(Rainer)]
* [http://lists.osgeo.org/pipermail/grass-user/2015-June/072540.html
(Pietro)]
* [http://lists.osgeo.org/pipermail/grass-stats/2015-June/001532.html R
interface to grass 7.1]
* [http://lists.osgeo.org/pipermail/grass-dev/2015-February/073861.html On
GSoC Proposal "New easy-to-use command line interface for GRASS GIS"
(Moritz)]
* [http://lists.osgeo.org/pipermail/grass-dev/2015-February/073867.html
On GSoC Proposal "New easy-to-use command line interface for GRASS GIS"
(Vaclav)]
* [http://lists.osgeo.org/pipermail/grass-dev/2015-January/072979.html
QGIS Processing & GRASS]
Related tickets:
* #2424
* #2679
* #2681
* #2639
* #2685
* #2511
* #2678
Ticket URL: <https://trac.osgeo.org/grass/ticket/2579#comment:15>
