[GRASS-dev] [GRASS GIS] #2618: v.category option=transfer does not copy multiple cat values
trac at osgeo.org
Tue Jun 16 07:30:10 PDT 2015
Reporter: ulf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: 7.0.0
Resolution: | Keywords: v.category transfer
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
I added the commands as a Bash test case in r65485 but I actually don't
understand what the output means here (why it is the same for `layer=1`
and `layer=2`?) and what `option=transfer` does. It would be good if
somebody can review it and/or comment in the test.
Side note: The Bash script tests (test cases, test files) are really easy
to create. Just look at r65485. They have a lot of problems and the
solution is not scalable but it is better than no test!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2618#comment:4>
