[GRASS-dev] [GRASS GIS] #2304: Problems with add category to all features workflow
GRASS GIS trac at osgeo.org
Tue Jun 16 08:03:41 PDT 2015
  Reporter:  wenzeslaus   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Default      |    Version:  unspecified
Resolution:  fixed        |   Keywords:  v.edit, v.category
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by wenzeslaus):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replying to [comment:6 mlennert]:
 > I again suggest closing this bug, as there is no actual bug report in
 here.
 OK, significant amount of reported things was either fixed or resolved
 somehow. But some of the unresolved issues would be good to keep in mind,
 for example module option called `option`, and I guess I may hit the
 remaining ones once I will work with vector categories again if they are
 still there. I've tried to run some of the commands from the original
 report and the problems with `v.edit` are still fixed (comment:5), so
 that's fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2304#comment:7>
